Нов във форума, нов със Шкода
retsboc
Регистриран на: 28.08.2018, 14:39:07
Мнение от retsboc »
А, и... имате ли някой сайт или програма за проверка на VIN? Или някой ако може да помогне някак? Малко след дъжд - качулка, ама все пак да си видя майчиното мляко на колата.
Намерих тук един сайт, чрез търсачката на форума, който дава уж всякаква информация, със сигурност повече от "безплатните", които намирам в интернет.
Но все пак. TMBHT61Z6B2026538
Parameter Value
Brand SKODA
Model OCTAVIA COMB.AMBIENTE
VIN TMBHT61Z6B2026538
Check digit Ok
Sales id 1Z5224
Permanent link http://carinfo.kiev.ua/cars/vin/skoda/v ... pglczk9ov6
Production date 2010-08-18
Model year 2011
Engine code CAYC (TDI CR)
Engine volume, L 1.60
Number of cylinders 4
Power, KW 77
Power, PS 105
Colour of body 1Z (BLACK: black magic pearl effect)
Trim CS
Gearbox code LHW (5S)
Country of sale 000 ()
Custom options
Parameter Value
E0A Special editions: No special edition
1PF Lockable wheel bolts: Standard wheel bolts
ND0 Adapter (for trailer hitch): Without adapter
0HF Vehicle class differentiation units/platform components: Vehicle class differentiation 1Z0
0P0 Exhaust tailpipe: Rear exhaust tailpipe (standard)
UG0 Hill start assist: Without hill hold control / hill descent control / comfort driving assist
7MG Emissions standard: Emission standard EU5
1D0 Trailer hitch: Without trailer hitch
4UF Airbag: Driver's and front passenger air bag with front passenger air bag deactivation
1E0 Activated carbon canister: Without activated charcoal canister
3Z0 Storage compartment: Without stowage box
QE4 Storage compartment package: Tray areas package 2
7N2 Tray: Spectacle tray/bracket
8L5 Antennas: Roof antenna and "diversity" window antenna
6XD Exterior mirror setting: Exterior mirrors: electrically adjustable/heated
9GG Interior light in driver compartment: Two interior lights with door pillar switches
5SL Left exterior mirror: Left exterior mirror: aspherical
5RQ Right exterior mirror: Right exterior mirror: convex
1X0 Drive layout: Front wheel drive
9Y1 Outside temperature display: Outdoor temperature gage
9WR "Multimedia", video/DVD/notebook connection: Installation of audio connection
A8C Equipment levels: Comfort equipment
1KD Brake type in rear: Disc brakes, rear
J0N Batteries: Battery 330 A (61 Ah)
1ZF Brake type, front: Disc brakes, front (Geomet D)
6FB Components with special surface appearance: Body-colored exterior mirror housings
4LB Controls (steering wheels/steering column): Radio control
7V0 Dashboard illumination: Standard dashboard illumination
NY0 Battery/alternator capacity: Standard battery/alternator capacity
B0J Component part sets with country-specific design requirements: Component parts set, complying with vehicle type for Italy, various parts
1S1 Tool kit and jack: Tool kit and jack
1AT Brake systems: Electronic stabilization program (ESP)
0VG Owner's manuals: Information kit in Italian
9U1 Brake pad wear indicator: Brake pad wear indicator
9T0 Heated washer nozzles: Without heated washer nozzles
7QA CD ROM/DVD/SD card: Without CD/DVD for navigation
7A0 CD changer/CD player: Without CD changer/CD player
2H0 Charism: Without "drive select"
QJ1 Chrome package: Chrome work package
C00 General operating permit, alterations: Operating permit, initial registration
0C0 CO2 variant: Standard
3S2 Roof rails/roof load rack: Black roof rails
3FA Roof insert/convertible top: Without roof insert (standard roof)
1JA Suspension system in rear: Rear shock absorption, basic design 1
G02 Suspension system in front: Front shock absorption
3X0 Ski bag: Without load-through provision
2G5 Insert for the filling up of unleaded fuel/fuel type: Filler neck module 1 without insert
0EJ Installation differentiation for vehicle components: Installation differentiation for transmission MQ 250 vehicle components
7AH Theft protection system: Electronic vehicle immobilization device with alarm system, passenger compartment control and backup horn
5MD Inserts: Decorative aluminum inserts
7M5 Scuff plates: Without protective film for scuff plate
7X1 Park distance control: Park distance control
UF0 Electric interface for external use: Without electric interface
0FA Manufacturing sequence differentiation: Standard manufacturing sequence
AZ0 Vehicle type: Vehicle with standard production scope
4R4 Window regulator: Power windows with comfort operation and circuit breaker
6A0 Fire extinguishers: Without fire extinguisher
9HA Malfunction display: Without additional malfunction display
VL0 Pedestrian protection: Standard pedestrian protection measures
5NA Hood and trunk stay: Hood stay
VF0 Pedal cluster: Standard pedal cluster
8K3 Headlight control: Separate daytime running lights with low beam assistant and "Coming Home" feature
F0A Vehicle specifications: No special purpose vehicle, standard equipment
3W0 Interior noise suppression measures: Without additional noise suppression measures for passenger compartment
NG0 Top carrier: Without top carrier
8GU Alternators: Alternator 140 A
0YE Weight category rear axle: Weight range 5 installation control only, no requirement forecast
L07 Weight category front axle: Suspension range 07 installation control only, no requirement forecast
TF3 Base engine: 4-cylinder diesel engine 1.6 L 03L.1
3U2 Luggage compartment cover: Sliding trunk cover
6M5 Tie down straps/net/pocket: Trunk net
8T2 Cruise control system: Cruise control system (CCS) electronic
9E3 Luggage compartment lighting: Luggage compartment lighting
G0C Transmission specifications: 5-speed manual transmission
6Y0 Cruise control system and speed limiter: Without cruise control warning system
4Z5 Glove compartment: Glove compartment door with light
6PE Hand brake lever handle: Leather hand brake lever handle
8M1 Rear window wiper and washer system: Rear window wiper and washer system with intermittent control
5N2 Grab handles at roof frame: Folding grab handles at roof frame
3KD Rear seats: Rear seat bench/backrest, split folding
9AK Heating and air conditioning system: Climatronic with impact pressure control free of cfc
8JH Headlamps: Ellipsoidal headlight for driving on the right
6T0 Interior light in footwell: Without interior light in footwell
U4A Instrument clusters: Instrument insert, km/h speedometer
4N1 Dashboard: Padded dashboard
4L6 Breakaway interior rearview mirror: Breakaway interior rear view mirror, automatically dimming
K8D Body style: Station Wagon Variant/Avant
6SA Luggage compartment floor covering: Without trunk floor covering
1W2 Refrigerator: Glove compartment cooling system
QS0 Electronic map cooling system: Without electronic map cooling system
QA0 Child seats: Without child seat
3N2 Lids/storage compartments in trunk: Stowage box with cover in luggage boot side panel
0Y1 Climatic zones: Standard climatic zones
QR0 Compass/road sign display: Without compass/traffic sign display/ traffic signs recognition
3Q6 Rear head restraints: Three rear headrests
3J1 Head restraints: Height-adjustable headrests for front seats
2LD Fuel tank treatment: Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
1Z2 Fuel quantity for initial filling: Increase in initial standard fuel filling
0F3 Fuel systems: Fuel system for diesel engine
5C0 Body measures: Without special body measures
3G0 Child seat anchor in front: Without child seat anchor front (ISOFIX)
5K5 Paint preservative/transit coating: Transit coating film with additional transport protection measures
FB0 Paint coating: Standard paint coating
3GA Rear luggage/load compartment floor: Without cargo area
L0L Steering system arrangement: Left-hand drive vehicle
8S5 Reading light: Two reading lights front
1N3 Steering: Speed-related variable steering assist (Servotronic)
3H0 Backrest release: Without backrest release for front seats
VK0 Air duct, front area: Air duct, standard
7P4 Lumbar support: Manually adjustable lumbar support in front seats
1XA Steering wheels: Multi-function steering wheel
8RE Speaker installation: 4 speakers (passive)
8Q1 Headlight range control: Headlight-range adjustment
6E3 Center armrest: Front center armrest
9Q2 Multi-function display/trip computer: Multi-function display/on-board computer with check control
3D1 Center console: Center console
8Z5 Engine cooling system: Not hot country
D38 Engine specifications: 4-cyl. turbo dies. eng. 1.6 l/77 kW (4V) TDI common rail Base engine is TF3/TN1/TJ1
4SB Left vanity mirror: Vanity mirror left
4TB Right vanity mirror: Vanity mirror right
7Q0 Navigation device: Without navigation device
8TC Rear fog lamp: Rear fog light for driving on the right
8WB Front fog lamp/additional headlamp: Front fog lights
GP3 Upgrading measures: Vehicles with special upgrade measures
4P3 Platform module, luggage compartment floor: Rear floor panel module, type 4
7PB Platform group class: Platform group class 2
GR0 Breakdown spray: Without emergency tire inflator
1NL Wheel covers: Covers for alloy wheels
C2P Wheels: Alloy wheels 6.5J x 16
8DN Radios: Radio "LOW I"
9JD Smoker's/non-smoker's package: Smoking package, ashtray front
7K0 Direct tire pressure monitoring system: Without tire pressure warning light
HH7 Tires: Tires 205/55 R16 91V
V0A Tire suppliers: Tires w/o specification of tire brand
1G2 Spare wheel/breakdown kit: Steel spare wheel with original equipment tires
3QT Restraint systems, front: 3-point seat belts with tensioner and height adjustment, front
PJB Steel spare wheel, car jack, wheel wrench
PK2 Hight adjustable driver and passenger seat with lumbar support
PW0 Heated front seats
4X3 Side airbag: Side air bag front with curtain air bag
6Q5 Gearshift knob/handle: Sports gearshift knob
2KY Special labels/plates: Labels/plates in Italian, Spanish and Portuguese
3TB Front seat, left: Standard seat, front left
3SB Front seat, right: Standard seat, front right
9P1 Seat belt check: Seat belt reminder, electric contact in buckle
3ZB Outer rear seat belts: 3-point seat belts, outer rear with ECE label
3C7 Center rear seat belts: 3-point seat belt for center rear seat
N0D Seat trim covers: Fabric seat covering
3L3 Seat adjustment: Manual height adjustment for front seats
4A3 Seat heater: Seat heater for front seats separately controlled
3K0 Safety head restraint system: Without safety headrest system
7R6 Side lights: Side turn signal lights in exterior mirrors
8QL Key for locking system: Key for locking system with remote control
7L3 Start-stop system/regenerative braking: Without start/stop system without regenerative braking
8Y1 Horns: Two-tone horn
4KC Side and rear windows: Side and rear windows in heat-insulating glass
4B2 Protective side molding: Body-colored protective side molding
3Y0 Roll-up sun screen for rear and side windows: Without roll-up sun screen
7B2 Socket: 12-volt socket in luggage boot
2JB Bumpers: Standard bumpers
0BD Rear stabilizer bar: Rear stabilizer
8NB Parking light indicator light: Parking light indicator light
0AE Front stabilizer: Front stabilizer
QN2 Drawers under front seats: Drawer under right front seat
2UA Heavy-duty/sports version: Standard design
8X0 Headlamp washer system: Without headlight washer system
8N3 Windshield wiper intermittent control/ light/rain sensor: Windshield wiper intermittent control with rain sensor
6N0 Mud flap: Without mud flaps
1RX Nameplate set: Nameplate set in base trim
2W3 Fuel filler cap/door, locking option: Fuel filler cap remote unlocking
1Q0 Mass damper for steering wheels: Without mass damper for steering wheel
4K3 Door and lid locking system: Radio remote controlled central locking operated from inside and safe securing
B14 Type approval countries/countries with special requirements: Type approval Italy (San Marino, Vatican City)
5D1 Carrier frequency for radio remote control: Carrier frequency 433.92 MHz-434.42 Mhz
3CA Partition: Without partition
3LT Door and side trim panels: Door and side trim panel
0A2 Doors: 4 doors
QV0 TV reception/digital radio reception: W/o TV reception/digital radio reception
1SA Front underbody guard: Without additional front underbody guard
1EX Identification plates: Special identification plate for EC for M1 passenger vehicle
2A0 Delivery equipment: Without delivery equipment
1T0 First aid kit / warning triangle: Without first aid kit and warning triangle
9W0 Telephone / telematics: W/o car phone preparation/installation
9TB Additional warning lights: Additional warning lights (door area)
QG1 Service interval prolongation: Service interval prolongation
7E0 Heat accumulator system/auxiliary heater: W/o heat accumulator/auxiliary heating
4GF Windshield glass type: Windshield in heat-insulating glass
8W0 Washer fluid level indicator: Without washer fluid level indicator
0TA Floor mats: Without floor mats
6EP Additional body covers, side: Additional stone guard body covers
3B4 Additional child seat anchors: Child seat anchor for child seat system ISOFIX
9M0 Auxiliary heater: Without auxiliary/parking heater
SimichOil
Местоположение: Русе
Мнение от SimichOil »
Toя сайт пък при мен никога не работи....винаги ми излиза :
Error detecting the car
lubomirov1985
Мнение от lubomirov1985 »
Честито, колега и добре дошъл. Много безаварийни километри
Бирата е божествена напитка!
stanley
Мнение от stanley »
Това мисля показва, че липсва окомплектовка за телефон:
Това поквза, че имаш окабеляване за свързване с аудио плеър (аудио жак)
Никъде не видях да пише нещо конкретно за bluetooth.
От това видео се разбира горе долу как изглежда модула и къде е поставен:
retsboc
Мнение от retsboc »
Мда. Май нямам такава кутия. Нищо, ще му е кахъря после. Или пък не :)
Приятели, имам няколко питания пак, след като покарах малко. Чисто функционални:
1. Как да ресетна брояча за километрите - този вдясно, дето може да се нулира. На старото ми Пежо натисках ръчката, излизаща от километража и готово. С този MFD не се оправих лесно. Натисках скролерчето на волана, но ми ресетна само текущите време, изминато разстояние и среден разход. Долу вдясно до "големия" километраж продължава да си стоят едни 300-400 километра, които искам да нулирам.
2. Имам парктроник сензори само отзад. Но когато включа на задна, примигват черти на дисплея и отпред. Това означава ли, че ако се сложат сензори, системата може да се пригоди да отчита и съответно да показва разстоянието до даден обект пред автомобила?
Поздрави и успена седмица!
По точка 1 имаш ли го това?
retsboc
Мнение от retsboc »
Да, имам. Опитвах да го въртя, натискам... Нищо не стана.
А като го задържиш натиснато?
retsboc
Мнение от retsboc »
Да, сработи. Явно не съм бил включил на контакт първия път.
А... хора... този ми модел с ангренажен ремък ли е или с верига?
retsboc
Мнение от retsboc »
И малко нахално, но пак имам питане: вчера като шофирах, колата автоматично се заклюваше. Светваше долу копченцето до скоростния лост. Отключвам и след минута - пак се самозаключва. Когато после опитам да отворя вратата, трябваше един път на празен ход да дръпна, и после се отвори. Единствената разлика с предишни шофирания беше, че карах с резервния ключ (който забеляах, че има малка червена лампичка). Може ли е да е някаква настройка или нещо свързано с аларма?
Дърпайки един път - отключваш и следващия път - отваряш. А за автоматичното заключване мисля, че се изключва през VAG-COM. Лично за мен е доста полезна глезотийка! На светофар са се опитвали да ми отварят задната врата. А и за дечурлига е хубаво да са заключени
retsboc
Мнение от retsboc »
Благодаря! Най-вероятно ще да е така - мистерията е защо е включено с единия ключ, а с другия - не е.
И да дам малко сведения: днес официално минах при "мой майстор", доверен човек. Закачихме я на компютър, хууубаво я огледахме, подробно. Не показа никакви грешки системата. Огледа хубаво двигателя, единствената му забележка беше, че трета дюза "давала по-високи стойности" - на моменти се качваше числото до 1, на останалите беше стабилно около 0 и под. Каза ми, че ако се вдигне над 2 значи е заминала дюзата. Но това съм щял да го усетя по пушене и голям разход на гориво. Също каза, че е възможно и да си я сменя тази дюза. Посъветва ме да карам или със скъпата нафта, или да слагам добавки.
Дайте мнение, хора, каква добавка да сложа за този двигател?
А, и още нещо! Майсторът я гледа, гледа, според него е удряна. Но най-вероятно е бил лек удара, защото добре са го направили и не е засегнато нищо по предницата - вероятно само бронята, което (сега навързвам) обяснява липсата на сензори отпред за парктроника. Това ми дава надежда, че ако се сложат самите джиджавки, ще може да се навържат към системата, нали?
Масово ползваните добавки са Бардал и Ксенум. Ама дали има полза от тях не се наемам да коментирам. Това, което е сигурно е, че смърдят ужасно гадно и ужасно дълго като се олееш, та внимавай.
niki
Гараж: Фабия 1 комби 2006 ASY
VW Golf 1997 AHU
Volvo XC70 D5
Мнение от niki »
Аз на октавия 2 не съм виждал преден парктроник. Може и да има, но аз не сйм го виждал.
