Помощ за отстраняване на някои грешки
Nikolaycenov
Местоположение: Димитровград
Гараж: '18 Skoda Superb SportLine 2.0 TDI, DSG7, 150кс
Мнение от Nikolaycenov »
Днес се сдобих с Шкода Октавия 2 Елеганс Комби 2006 година мотор BKC с DSG кутия HQN. Колата е супер :)
Като купувах колата я закачих с vcds и показа само грешка с антената. Но на другия като се порових и изпробвах повечето модули по колата се появиха някой грешки и за капак и егр-а :)
ABBC3_OFFTOPIC
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 BE HW: 028 101 194 7
Component: R4 1,9L EDC G000AG 7000
Revision: 12345678 Serial number: SKZ7Z0E3087044
Coding: 0000078
Shop #: WSC 73430 790 00000
VCID: 67D9BFAF2FFD
1 Fault Found:
16785 - EGR System: Insufficient Flow
P0401 - 000 - -
Freeze Frame:
RPM: 1344 /min
Torque: 54.0 Nm
Speed: 39.0 km/h
Load: 15.3 %
Duty Cycle: 14.7 %
Bin. Bits: 00101000
Mass Air / Rev.: 245.0 mg/str
Mass Air / Rev.: 490.0 mg/str
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 H HW: 02E 927 770 AE
Component: GSG DSG 070 0910
Revision: 04507000 Serial number: 00000506290564
Coding: 0000020
VCID: 183BCC535203
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F8947CF17ED
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3B7133DF03F5
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000003417544
Coding: E18A0F030004140000110D000000000000087F075C
VCID: 3A7F36DB0CCF
Part No: 1Z1 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
Part No: 1K0 955 559 AB
Component: RLS 020507 020 0105
Coding: 00208933
Shop #: WSC 73430
1 Fault Found:
02401 - Terminal 75x
006 - Short to Plus - Intermittent
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: Q2 AIRBAG VW8 015 2100
Revision: 03015000 Serial number: 0038ED0FH5RG
Coding: 0020786
VCID: 37792FEF3FDD
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 034 0070
Coding: 0012042
VCID: 77F9EFEF7F5D
Part No: XXXXXXXXXXX
Component: E0221 007 0050
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 841 D
Component: KOMBIINSTRUMENT VD1 0918
Coding: 0007101
Shop #: WSC 80093 222 71269
VCID: 37792FEF3FDD
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001056038D8A
Coding: 3F3F0740072302
VCID: 2A5F069BFC6F
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 0918
VCID: 37792FEF3FDD
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2345
Coding: 0000246
VCID: 366722EB38D7
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 326F1EFBD4BF
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 10D002007F2D8505484F861004CC
Shop #: WSC 20041 264 11418
VCID: 79FDE9D74949
Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000246
VCID: 37792FEF3FDD
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 B HW: 1Z0 035 161 B
Component: Radio FO3 012 0023
Revision: 00012000 Serial number: SKZ7Z3E0017255
Coding: 0000400
VCID: 2D550D87CD81
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2405
Coding: 0000144
VCID: 326F1EFBD4BF
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
VCID: 33611BFF2BA5
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0001001
VCID: 3D753DC71DE1
та някои горе долу знам както да ги правя но други не.
от първата
ABBC3_OFFTOPIC
P0401 - 000 - -
Freeze Frame:
RPM: 1344 /min
Torque: 54.0 Nm
Speed: 39.0 km/h
Load: 15.3 %
Duty Cycle: 14.7 %
Bin. Bits: 00101000
Мисля да се свали ЕГР и Клапата и да се почистят. Според вас това ще реши ли проблема.
ABBC3_OFFTOPIC
Това нищо не ми говори ... моля за помощ
ABBC3_OFFTOPIC
Доколкото разбрах това е дефект за малкото копченце за скоростта на чистачките и за рейн сензора... Трябва цял нов лост или може да се отремонтира ?
ABBC3_OFFTOPIC
Според прочетеното антената (на диагностиката радиото като се задържи MENU пише ANT- OFF) е за смяна (тя е една такава сгъваема, която не се вади ) активна и май е изгоряла. Май трябва да се свали част от тавана и да се отвие гайката М22 за да се свали антената. Някой знаели каква и е цената?
Допълнителни въпроси:
1. Като тръгне колата всичко се заключва. Като спра трябва 2 пъти да дръпна лосчето за отваряне да за да отворя и се отваря само шофьорската врата. В кой модул да търся това за да го изключа, и какво точно да търся?
2. Като дам копчети на темпомата за ON никъде не ми изписва на големия черен диспей на колко км съм сетнал скоростта, и никъде няма по таблото че съм на ON на темпомата?
3. Може ли да този големия дисплей може ли да показва моментната скорост.
4. Колата има настройка за изпращане и посрещане с фаровете, който се настройват от диплея. Забелязах че като остава ключа на фаровете включен и заключа колата след режима за изпращане гаснат. Може ли да направи така че като изкарам ключа на включени светлини да си гаснат и после като се заключи да се изпълнява тази функция по изпращането до вкъщи?
5. На колоната до шофьора има копче май за аларма или не знам .. кола с антенка ми прилича ... как работи??
6. Как се пускат пръскалките на предните фарове?
има и други ама сега не се сещам :)
... да.. някъде има ли потребителска инструкция на български ???
Честито ти за новата придобивка.Мн.безаварийни километри.
На въпросите мога на всички да ти отговоря,но не ми се пишат фермани,за това ще ми се обадиш по тел.ако искаш.
Nikolaycenov
Така, да кажа какво съм отстранил, може да съм в помощ на някой колега.
Антената на радиото: Антената бе свалена и разглобена беше намокрена и имаше корозирала писта т.е. прохода между долен и горен слой на платката. За целта се налага разпробиване на нитованите части, за да може да се стигне до долния край на платката. След ремонта добре уплътнена с силикон. На диагностиката на радиото вече пише АНТ ОН [:)]
Грешката с ключа на мигачите: Разглобява се на място с перце от китара, фоно-карта или в моя случай перце за разглобяване на ГСМ-ми. Платката беше на букса. Сваля се платката чистят се графитните площадки със спирт, и ако имате наличен спрей за потенциометри може да ги пръснете ако не .. оставяте ги така на сухо, и леко закривявате пластинките за по добър контакт.
EGR: беше свален в сервиз и почистен (имаше мноого нагар). След почистването колата е по-пъргава в ниските обороти и над 120 има повече мощност.
Кодирах си фаровете на DRL Scandinavia и ги димнах на 50%.
Махнах си автоматичното заключване на вратите
Пръскалките на предните фарове се пускат на всяко 5-то пръскане с предните пръскалки
НЕРЕШЕНИ ВЪПРОСИ:
ABBC3_OFFTOPIC
1 Fault Found:
нищо не мога да намеря по този въпрос.
Темпомата няма нито лампа нито индикация на сетнатата скорост.
И последното дали може да се показва моментна скорост на MF диспея?
Сега мисля да се обадя на колегата да видим какво ще ме посъветва :)
ЕДИТ: Колега номера ти не работи, който ти е в профила.
Ако е слаган допълнително темпомата,няма да има индикация на таблото.
Максдидота показва моментна.
Грешката оже да е от 3 причини.
Nikolaycenov
Сега проверих в ЕТКА по ВИН и наистина пише, че е без сигнализатор на темпомата, но има заводски темпомат.
ABBC3_OFFTOPIC
6Y0- without cruize control warning system
8T2-Cruize control system (CCS) electronics
някакъв шанс да се активира чрез VCDS да се показва на Максидота и май няма лампа в таблото?
Бай Ненчо
Гараж: ПОД НАЕМ
Мнение от Бай Ненчо »
Честита да ти е колега, много да те радва :)
Скоро да я покажеш тази красавица ;)
Nikolaycenov написа:Сега проверих в ЕТКА по ВИН и наистина пише, че е без сигнализатор на темпомата, но има заводски темпомат.
ABBC3_OFFTOPIC
Допълнително е слаган сигурно.
Не съм виждал заводски без индикация.
Той като е сложен,се кодира в инструменти и двигател но не светва индикация.
Ако е преди фл колата и има макси дот,не показва монентна скорост не на темпомата,надисплея
