Страница 1 от 1
Octavia 1,6 TDI лог файл с грешки
Публикувано: 09.07.2018, 22:03:52
от mischoka
Пускам с молба от приятел, ако може да се определи кои от грешките са сериозни и кои могат да се игнорират.
Koлата е с 7ДСГ 105 коня
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 N HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5518
Revision: 84H22---
Coding: 01250012032401091000
Shop #: WSC 73430 031 00101
ASAM Dataset: EV_ECM16TDI01104L906021N 002009
ROD: EV_ECM16TDI01104L906021N_002.rod
VCID: 30F028FC1F027552D5-8064
4 Faults Found:
5604 - Park/Neutral Switch Input Circuit
P0850 00 [032] - Open or Short to Plus
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 5
Mileage: 90688 km
Date: 2018.03.26
Time: 15:23:31
Engine speed: 915.50 /min
Normed load value: 37.6 %
Vehicle speed: 0 km/h
Coolant temperature: 50 °C
Intake air temperature: 37 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 14.760 V
Unlearning counter according OBD: 26
Starter control: Interlock- or P/N-signal-Bit 0: 1
Brake actuated status-Bit 0: 0
Selector lever position-Bit 0: 8
Transmission neutral position sensor: adaptation status-Bit 0: 0
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 90688 km
Date: 2018.03.26
Time: 03:45:59
Engine speed: 820.00 /min
Normed load value: 34.1 %
Coolant temperature: 21 °C
Intake air temperature: 20 °C
Voltage terminal 30: 11.880 V
Unlearning counter according OBD: 25
17158 - Databus
U1123 00 [032] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 90688 km
Date: 2018.03.26
Time: 03:45:59
Engine speed: 873.00 /min
Normed load value: 34.9 %
Voltage terminal 30: 11.920 V
Drivetrain coordinator: ACC fault status-Bit 0: 0
Drivetrain coordinator: ACC fault status-Bit 8: 0
Drivetrain coordinator: brake fault status-Bit 0: 4
Drivetrain coordinator: brake function status-Bit 0: 0
Drivetrain coordinator: brake function status-Bit 8: 0
Acceleration: 0.000 m/s²
21125 - Invalid Data Received from Airbag Control Module
U0452 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 90279 km
Date: 2018.03.04
Time: 17:44:56
Engine speed: 771.00 /min
Normed load value: 43.1 %
Coolant temperature: 79 °C
Intake air temperature: 60 °C
Voltage terminal 30: 14.480 V
Unlearning counter according OBD: 36
Limitation: accelerator pedal: 0.0 Nm
CAN status - engine control module-Bit 0: 0
Cruise Control System (CCS): status-Bit 0: 0
CAN status - transmission control module-Bit 0: 0
CAN status - brake control module 1-Bit 0: 0
CAN status - brake control module 2-Bit 0: 0
selected gear-Bit 0: 0
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 044 S HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5241
Revision: 00043014 Serial number: CU501306075973
Coding: 0014
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW26.rod
VCID: 480858347F9AE5FA95-801C
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 61583000000241
Coding: 1A0762912422096F007C060641C5245846249000608224F000410070C002
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 4B1552036B8B1B918D-801E
2 Faults Found:
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 90688 km
Date: 2018.03.26
Time: 03:45:58
16390 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 90688 km
Date: 2018.03.26
Time: 03:46:08
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0193573144
Coding: 030C0C
Shop #: WSC 73430 790 00101
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3A0634DE375CB11805-806E
Address 08: Auto HVAC (J255) Labels:. 5G0-907-044.clb
Part No SW: 5E0 907 044 C HW: 5E0 907 044 C
Component: Climatronic H02 0604
Revision: 00001K06
Coding: 01010104002100011005000100100000
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_002.rod
VCID: 25EB1E9DC335378F7D-8070
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
2 Faults Found:
590081 - Control Circuit for A/C Compressor
B10A9 11 [008] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 90478 km
Date: 2018.03.13
Time: 10:31:47
Outside air temperature: 12.0 °C
Engine speed: 1600 /min
Compressor shut-off requirement: Compressor activation: malfunction in activation path
Compressor current: actual value: 0.005 A
Compressor current: specified value: 0.000 A
263426 - Air Quality Sensor
B10AF 31 [008] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 58
Mileage: 90227 km
Date: 2018.03.02
Time: 14:50:35
Voltage terminal 30: 11.5 V
Outside air temperature: 3.5 °C
System run time-Engine running time: 255 s
System run time-Terminal 15 on: 255 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 BCM MQBAB H H14 01120112
Serial number: 00011315701504
Coding: 0C011A66424722FB07A04082B11C07080808000000000000000000000000
Shop #: WSC 07575 002 1048576
ASAM Dataset: EV_BCMCONTI 011001
ROD: N/A
VCID: 7739BA873BAF034DED-8022
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 130614 041 0570
Serial number: 130615202912
Coding: 065DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M06D20H19M26S07S1
Coding: 02805D
Sensor For Anti Theft Alarm System:
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY131081SRG
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000057049410
1 Fault Found:
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 104
Mileage: 87196 km
Date: 2017.11.01
Time: 21:24:59
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231316600157
Coding: 0031051051
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_EPHVA18AU3700000 002019
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 3B0532D32B5BBB210D-806E
1 Fault Found:
13637426 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 90688 km
Date: 2018.03.26
Time: 03:45:59
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 AA HW: 3Q0 959 655 AA
Component: Airbag VW20 011 0188
Revision: -------- Serial number: 003NYPAEE6MM
Coding: 98FCC000000000005C5400CC000800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7D43CE95238D27773D-8028
Belt Pretensioner left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H35 0340
Serial number: 34169593B20061350028
Coding: 333135
Belt Pretensioner right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H35 0340
Serial number: 34169592B14061370390
Coding: 333135
Side Sensor Driver Front:
Subsystem 3 - Part No SW: ----------- HW: 454 000 306 13
Component: SideSensor_Df 008 0887
Serial number: 3576U000000E11592D0A
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 4 - Part No SW: ----------- HW: 454 000 306 13
Component: SideSensor_Pf 008 0887
Serial number: 3586U0000008E9492D0P
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 5 - Part No SW: ----------- HW: 454 803 105 13
Component: SideSensor_Dr 111 0148
Serial number: 3516RFE226101000000/
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 6 - Part No SW: ----------- HW: 454 803 105 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R3B957A010000003
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 7 - Part No SW: ----------- HW: 454 802 303 13
Component: FrontSensor_D 114 0149
Serial number: 3556V66352901000000$
Coding: 2D2D2D
1 Fault Found:
1050117 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 90688 km
Date: 2018.03.26
Time: 03:46:00
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 507 BP HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 11061304221062
Coding: 1400
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 05CBDE7D435577AF7D-8050
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5E0 920 871 D HW: 5E0 920 871 D
Component: KOMBI 333 2210
Coding: 07A402182980000801086A00000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 29F716E9F3212FA39D-807C
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000662255
Coding: 030100040B087300EF00064E1C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
Component: E221__MFL-PR6 H04 0120
Serial number: 000000000B0021160613
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 2658210603
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 5Q0 905 861 HW: 5Q0 905 861
Component: ELV-MQBA H06 0010
Revision: 00000000 Serial number: 13000106658004
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMQB 003008
ROD: EV_ELVMarquMQB_003.rod
VCID: 733DA28B0BB3EBA9CD-8026
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000064852106
Coding: 00150020D000028000001100
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
VCID: 02CEC4665764419045-8056
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000277500
Coding: 010200
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 01
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D034ED5234DA7373D-8068
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000064862425
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
VCID: 01CFC66153795F8B5D-8054
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000266226
Coding: 190200
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: ----------
Coding: 03CA02003F010000
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-HGH1.clb
Part No SW: 5E0 035 043 A HW: 5E0 035 043
Component: MU-H-N-EU H41 MU-H-N-EU H41 01810181
Serial number: A312E0DB001065
Coding: 03730101FF00000011110001000000002F0000840100010076
ASAM Dataset: EV_MUHig6C3HBAS 001041
ROD: N/A
VCID: 1AE6F4BEB7FCF13805-804E
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5E0 919 606 HW: 5E0 919 606
Component: ABT_High H44 0020
Serial number: SKZ8Z9N490050Y
Data medium:
Subsystem 2 - Part No SW: V03 959 800 MA HW: -----------
Component: ECE 2013/2014 --- 0062
Serial number: --------------------
Pedestrian Protection Contact:
1 Fault Found:
2562 - Navigation System
B126C F0 [008] - Navigation Database Faulty
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 75
Mileage: 90737 km
Date: 2018.03.28
Time: 08:23:59
Voltage terminal 30: 12.7 V
End-------------------------(Elapsed Time: 04:50)--------------------------
Публикувано: 09.07.2018, 22:51:00
от todor87
mischoka написа: 09.07.2018, 22:03:52 5604 - Park/Neutral Switch Input Circuit
mischoka написа: 09.07.2018, 22:03:52 21125 - Invalid Data Received from Airbag Control Module
U0452 00 [032] -
mischoka написа: 09.07.2018, 22:03:52 590081 - Control Circuit for A/C Compressor
mischoka написа: 09.07.2018, 22:03:52 263426 - Air Quality Sensor
mischoka написа: 09.07.2018, 22:03:52 2562 - Navigation System
Тези са "сериозни", останалите са най-вероятно поради откачане/смяна на акумулатора, следователно след изтриването им би трябвало да не се появят повече.
Публикувано: 09.07.2018, 22:54:38
от mischoka
Първата нещо с скоростната кутия ли е? На колата е сменян съединителя наскоро по гаранция, дали не са изчистили просто грешката или си има проблем?
Публикувано: 09.07.2018, 23:21:18
от todor87
Някъде нещо дава на късо. Огледайте добре кръглата букса, която влиза в мехатроника и кабелите за прекъсвания/счупвания и пр. НО изтрийте първо грешките и разбира се, ако пак се появи тогава гледайте [smilie=pardon.gif]
