потребление на ток
Публикувано: 16.02.2026, 10:12:08
In modern vehicles, connecting a battery charger or jumper cables to a chassis ground instead of the negative battery terminal is required for two primary reasons: electronic monitoring and explosion prevention.димон написа: 14.02.2026, 16:31:10 Относно зареждането на акумулаторЪт :
Един колега бе споменал , че минусЪт да се закача само и задължително към ламаринката удължител на терминала. Може ли да обясни защо това е необходимо и каква е разликата, ако я боцнеш направо на полюсЪт..!?
1. Battery Management Systems (BMS)
Modern cars are equipped with an Electronic Battery Sensor (EBS) or a Battery Monitoring Unit typically located on the negative terminal.
Accurate Data: This sensor monitors the state of charge (SOC) and state of health (SOH) by measuring current flowing in and out of the battery.
Avoiding Bypass: If you connect a charger directly to the negative post, the current bypasses this sensor. The car’s computer won't "see" the charge, potentially leading to errors in the start-stop system, incorrect alternator output, or premature battery failure.
Protection: Some manufacturers warn that a sudden surge from a high-powered charger could damage the sensitive control unit if connected directly to the terminal.
2. Explosion and Fire Safety
Standard lead-acid batteries emit flammable hydrogen gas, especially during charging or when they are deeply discharged.
Spark Mitigation: The final connection in a circuit often creates a small spark. By making this final connection on the chassis—away from the battery—you ensure any spark occurs far from the concentrated source of explosive gas.
Tool Safety: Using the chassis as ground reduces the risk of a "dead short". If your wrench accidentally touches a metal part of the car while you are working on the positive terminal, it won't create a massive short circuit because the chassis is at the same potential as the negative terminal.
3. Electrical Efficiency (Jump-Starting)
When jump-starting, connecting to the engine block or a designated ground point provides a direct path to the starter motor. This bypasses potential resistance from a heavily corroded or failed battery, ensuring maximum current reaches the starter.
Младите инжИнерчета са го измислили защо този минус трябва да стърчи до акумулатора
Аз лично като подавам ток минуса го закачам на скобата за вадене на двигателя (обикновено стърчи), ако няма отделно изнесен минус. По-дебело заземяване от това здраве му кажи
